Wavecor WF146WA01 5-3/4" Paper Cone Mid-Woofer 4 Ohm
- Black magnet parts for better heat transfer to increase power handling
- Gold plated terminals to prevent oxidation for long-term reliable connection - important in a car environment
- Built-in aluminum field-stabilizing ring for reduced high-level distortion
- Rigid stamped steel chassis with extensive venting for lower air flow speed reducing audible distortion
- Vented voice coil former for reduced distortion and compression
- Vented chassis for lower air flow speed reducing audible distortion
- Progressive suspension with specially designed conex spider for long durability under extreme operating conditions
We'll send you an email when Wavecor WF146WA01 5-3/4" Paper Cone Mid-Woofer 4 Ohm is back in stock or available for preorder.
