Wavecor WF118WA07 4-1/2" Balanced Drive Paper Cone Mid-Woofer with Truncated Frame 4 Ohm
- Vented voice coil former for reduced distortion and compression
- Vented chassis for lower air flow speed reducing audible distortion
- Balanced Drive motor with perfect force factor symmetry for reduced distortion
- Large motor system with 1-1/4” voice coil diameter and 80mm magnet for better control and efficiency
- Progressive suspension with specially designed conex spider for long durability under extreme operating conditions
- FEA optimized suspension for perfect symmetry, reducing even order harmonic distortion
- Long linear stroke motor for reduced distortion at high levels
We'll send you an email when Wavecor WF118WA07 4-1/2" Balanced Drive Paper Cone Mid-Woofer with Truncated Frame 4 Ohm is back in stock or available for preorder.
