Wavecor TW030WA02 30mm Textile Dome Neodymium Tweeter with Heat Sink and Ferrofluid
Wavecor
Part #298-2106
Wavecor
Part #298-2106
Model: TW030WA02
The Wavecor TW030WA02 is a high performance 30 mm textile dome tweeter that works extremely well for most demanding high frequency audio applications. The low resonance frequency and high-power handling makes TW030WA02 the ideal tweeter for 2-way speakers, where 1" tweeters will not do.
- Dual neodymium magnets for improved efficiency and improved magnetic shielding for A/V applications
- Flexible lead wires for higher power handling and larger excursion
- Precision-coated textile diaphragm for improved consistency and high-frequency extension
- Optimized dome shape for ultrahigh frequency cutoff
- Vented voice coil former for reduced distortion and compression
- High-stability ferro fluid for increased heat transfer from the voice coil
- Rear heat sink for increased power handling and reduced power compression
