  • Wavecor TW022WA02 22mm Textile Dome Neodymium Tweeter with Ferrofluid
CLEARANCE Wavecor TW022WA02 22mm Textile Dome Neodymium Tweeter with Ferrofluid
Wavecor
Part #298-2096
Wavecor
Part #298-2096
Model: TW022WA02
The Wavecor TW022WA02 is a 22 mm textile dome tweeter that is designed for compact installations. The TW022WA02 is an excellent choice for any project requiring high frequency reproduction in a compact space where a 1" tweeter may not fit.
  • 22 mm design for optimal compromise between on- and off-axis frequency response, resonance frequency, and power handling
  • External ring neodymium magnet for lower resonance frequency and distortion
  • Precision-coated textile diaphragm for improved consistency and high-frequency extension
  • Optimized dome shape for ultrahigh frequency cutoff
  • Vented voice coil former for reduced distortion and compression
  • High-stability ferro fluid for increased power handling
  • Gold plated terminals to prevent oxidation and ensure long-term reliable connection
The TW022WA02 is an excellent midway point between a 3/4" and a 1" tweeter. The optimized textile dome ensures wide dispersion and low distortion. Distortion is further reduced by efficient venting of the voice coil former.
BrandWavecor
ModelTW022WA02
Part Number298-2096
UPC848864054490
Weight0.15
Cone / Dome Diameter0.75"
Cutout Diameter2.1
Tweeter TypeSoft Dome
Power Handling (RMS)30 Watts
Frequency Response2,500 to 30,000Hz
Sensitivity88.5dB 2.83V/1m
Resonant Frequency (Fs)1150Hz
Voice Coil Inductance (Le)0.036mH
Mechanical Q (Qms)1.53
Electromagnetic Q (Qes)4.1
Total Q (Qts)1.11
Overall Outside Diameter2.56"
Depth0.9"
MONSTER DEAL
OF THE WEEK
$45.98 EACH
SAVE $12
Dayton Audio KABD-250 2 x 50W All-in-one Amplifier Board with DSP and Bluetooth 5.0 aptX HD
