Wavecor SW280WA01 11" Shallow Glass Fiber/PMI Foam Sandwich Cone Subwoofer 4 Ohm
Wavecor
Part #298-1078
Wavecor
Part #298-1078
Model: SW280WA01
The Wavecor SW280WA01 is an 11" low-profile, flat sandwich cone subwoofer that was designed for space-limited installations that require high performance. The incredibly shallow depth of the SW280WA01 is optimal for automotive installations.
- Dual surround suspension and flat cone design to minimize build-in depth
- Glass fiber/PMI foam sandwich cone to maximize bending stiffness leading to improved frequency response
- Innovative dual cone design to allow magnet mounting “inside” the cone resulting in reduced overall depth
- Balanced Drive motor structure for optimal drive force symmetry resulting in largely reduced even order harmonic distortion
- Vented center pole with dual flares for reduced noise level at large cone excursions
- Built-in aluminum field-stabilizing ring for reduced distortion at high levels
- Gold plated terminals to ensure long-term trouble-free connection
Your Price: $343.00
Only 2 In Stock
We'll send you an email when Wavecor SW280WA01 11" Shallow Glass Fiber/PMI Foam Sandwich Cone Subwoofer 4 Ohm is back in stock or available for preorder.
Free Shipping available on orders over $49.00 in the US. Details
