Wavecor SW182BD04 7" Balanced Drive Black Aluminum Cone Subwoofer 8 Ohm
Wavecor
Part #298-1058
Wavecor
Part #298-1058
Model: SW182BD04
The Wavecor SW182BD04 is a 7" aluminum cone subwoofer that was designed specifically for high performance compact subwoofer applications where sound quality and low distortion are the priorities. The SW182BD04 utilizes balanced drive motor technology for dramatically reduced distortion.
- Balanced Drive motor structure for optimal drive force symmetry resulting in largely reduced even order harmonic distortion
- Very rigid aluminum cone to ensure piston motion at high levels and for better heat transfer at high continuous power levels
- Low-loss suspension (high Qm) for better reproduction of details and dynamics
- Built-in aluminum field-stabilizing rings for reduced distortion at high levels
- Rigid die cast aluminum chassis with extensive venting for lower air flow speed reducing audible distortion
- Vented center pole with dual flares for reduced noise level at large cone excursions
- Vented voice coil former for reduced distortion and compression
