Wattgate 350i AU Black Gold Plated Audio Grade IEC Connector
- Cryogenically treated
- Perma-Lock™ terminals
- Accepts up to 10 AWG wire
- Audio Grade® IEC power connector
The years of development have finally produced a superior cord-end IEC. Gone are the days of wimpy, soldered contacts. The Wattgate 350i is here! The construction of the 350i is durable, featuring an elegant polycarbonate rear housing available in either black or clear with a durable hi-temperature rated front housing. The 350i has been designed to be adaptable to a wide range of power cables the removable insert can accommodate cable diameters from 0.300" (7.62 mm) to 0.655" (16.63 mm).
Installation has been further simplified due to clearly marked, tightly-spaced, funnel shaped holes to guide the conductors into the unique Perma-Lock™ terminals. The Perma-Lock terminals work in the following way: As the terminal screw tightens down on the contact tang, it compresses the wire underneath the tang, causing the screw to exert an upwards lift of the collar overleaf. This lifting action "locks up" the threads screws. Stress relieving of the terminals is virtually eliminated. Heat cycling and vibration cannot loosen the screw.
The real departure the 350i takes from the traditional IEC lies with the contact elements themselves. Their contacts are large and designed to posses a high spring rate to securely grip the connector on the component. In addition, a three-layer plating process is added: Oxygen free copper plating, electroless nickel, and finally 24k gold plating dramatically improves conductivity and prevents corrosion. Plugs are cryogenically treated, rated at 125 VAC, 15A, and accept up to 10 gauge wire.
Product Details | |
Brand | Wattgate |
Model | 350i AU BLACK |
Part Number | 110-435 |
UPC | 601431104352 |
Unit of Measure | Each |
Weight | 0.3 |
Product Specifications | |
Configuration | IEC |
Current Rating | 15A |
Power Connector Type | Cable Mount |
