Wattgate 330 RH evo Clear Audio Grade Rhodium Plated Edison Power Connector
- Pure rhodium plated audio grade AC power connector
- Accepts 8 to 14 AWG wire
- Use cable with a diameter up to 19 mm
- WattLock terminals for heavy duty wire capture
- Polycarbonate design with all non-magnetic materials
- High spring rate brass contacts
- 2.5 mm hex socket hardware holds individual wires tightly
2In Stock
We'll send you an email when Wattgate 330 RH evo Clear Audio Grade Rhodium Plated Edison Power Connector is back in stock or available for preorder.
