  • Visaton WG 220x150 Rectangular Waveguide for 1” Dome Tweeters
2 Questions, 2 Answers or
Visaton
Part #292-770
Visaton
Part #292-770
Model: WG 220x150
The Visaton WG220x150 is a premium 15 x 22 cm plastic waveguide, expertly designed for 25 mm tweeters. It features an exponential enlargement for a high sound pressure level gain in the lower high-frequency range, offloading the tweeter and enhancing audio quality. This waveguide also improves focus and coupling to a woofer by drawing the sound generation planes closer together.
  • 15 x 22 cm waveguide explicitly made for 25 mm tweeters.
  • Exponential enlargement that boosts the sound pressure level in the lower high-frequency range.
  • Improves focus and coupling to a woofer.
  • High-quality plastic construction for long-lasting durability.
  • Comes with 4 pieces M4 screws for straightforward tweeter connection.
Your Price: $16.98
MSRP: $22.24
Save $5.26 (24%)
Quantity:Qty: 1-9 $16.98/ea
Quantity:Qty: 10+$15.62/ea
The Visaton WG220x150 is a first-class 15 x 22 cm waveguide designed to enhance the performance of 25 mm tweeters. Constructed from high-quality plastic, it ensures robustness and durability for sustained use. The highlight of the WG220x150 is its exponential enlargement, which delivers a substantial sound pressure level gain in the lower high-frequency range. This design improvement not only augments the overall audio quality but also discharges the tweeter, increasing its longevity and efficiency. In addition, the WG220x150 improves both the focus of your sound and the coupling to a woofer. By bringing the sound generation planes closer together, it guarantees a richer and more immersive sound experience with detailed depth and clarity. The WG220x150 has been carefully adjusted in width and length to fit 13 cm (e.g., AL 130 8 Ohm) and 20 cm (e.g., AL 200 8 Ohm) loudspeakers. This compatibility makes it a versatile addition to your audio setup. Included with the waveguide are 4 pieces of M4 screws, each approximately 10 mm in length, facilitating an easy and secure tweeter connection. Enhance your sound system with the Visaton WG220x150 waveguide and experience improved audio performance.
BrandVisaton
ModelWG 220x150
Part Number292-770
Weight0.55
