  • Visaton TW6NG8 2" Cone Tweeter 8 Ohm
NEW Visaton TW6NG8 2" Cone Tweeter 8 Ohm
Visaton
Part #292-7800
Visaton
Part #292-7800
Model: TW 6 NG
The Visaton TW 6 NG is an 8 ohm cone tweeter engineered for high-frequency audio reproduction above 5,000 Hz, delivering a balanced frequency response with brilliant treble and high power handling. Its sealed rear design eliminates the need for a separate high-frequency enclosure, simplifying installation in various speaker configurations. This tweeter is particularly suitable as a replacement unit for many HiFi speakers, offering an effective solution for restoring or enhancing audio performance.
  • Frequency response ranging from 1,000 to 30,000 Hz for wide-range high-frequency reproduction
  • Opening angle of 97° at 8,000 Hz for broad sound dispersion
  • Excursion limit of ±0.5 mm ensuring precise diaphragm movement
  • Resonance frequency at 1,500 Hz contributing to clear high-frequency performance
  • Peak power handling of 100 W with a 12 dB/octave high-pass filter at 5,000 Hz for robust performance
NEW $15.75
Quantity:Qty: 1-9 $15.75/ea
Quantity:Qty: 10+$14.18/ea
Estimated back in stock 4/25/2025
Alert Me When Available
The TW 6 NG's design includes a 14 mm voice coil diameter and an effective piston area of 17 cm², contributing to its precise high-frequency reproduction. Its compact dimensions, with a cutout diameter of 56 mm and a net weight of 0.14 kg, facilitate easy integration into various speaker systems. The tweeter's construction ensures durability and consistent performance, making it a reliable choice for both new builds and replacement applications in high-fidelity audio systems.
Technical Data
  • Nominal impedance: 8 Ohm
  • Frequency response: 1000–30000 Hz
  • Mean sound pressure level: 91 dB (1 W/1 m)
  • Opening angle: (-6 dB) 97°/8000 Hz
  • Excursion limit :+/−0.5 mm
  • Resonance frequency fs: 1500 Hz
  • Magnetic induction: 0.8 T
  • Magnetic flux: 70 µWb
  • Height of front pole-plate: 2.5 mm
  • Voice coil diameter: 14 mm
  • Height of winding: 2.5 mm
  • Cutout diameter: 56 mm
  • Net weight: 0.14 kg
  • D.C. resistance Rdc: 6.5 Ohm
  • Effective piston area Sd: 17 cm²
  • Inductance of the voice coil: L 0.17 mH
  • Connections: 2.8 x 0.5 mm (+)/2.8 x 0.5 mm (-)
  • Peak power handling with high pass: 100 W(12 dB/Okt.; 5000 Hz)
  • Nominal power handling with high pass: 60 W(12 dB/Okt.; 5000 Hz)
BrandVisaton
ModelTW 6 NG
Part Number292-7800
Weight0.31
Cutout Diameter2.205
Power Handling (RMS)60 Watts
Frequency Response1000 to 30,000Hz
Sensitivity91dB 2.83V/1m
Resonant Frequency (Fs)1500Hz
DC Resistance (Re)6.5Ω
Voice Coil Inductance (Le)0.17mH
Overall Outside Diameter2.362"
Depth1.06"
