  • Visaton SC10N-8 1" Soft Dome Tweeter Shielded 8 Ohm
Visaton
Part #292-762
Visaton
Part #292-762
Model: SC10N-8
The Visaton SC10n-8 is a 1" fabric dome driver, designed for high-range frequencies above 3000 Hz. Magnet shielding, special dome coating and ferrofluid-cooled voice-coil offer high power handling and a linear frequency response. Perfectly suitable for medium-sized 2-way combinations for surround center speakers and multimedia systems.
  • Peak power handling of 150 W (with high pass) and nominal power handling of 100 W (with high pass)
  • 1" fabric dome driver for high-range frequencies of 1000–20000 Hz
  • Special dome coating and ferrofluid-cooled voice-coil for linear frequency response and high power handling
  • Magnet shielding allows for proximity to electronic equipment
Your Price: $27.95
MSRP: $36.99
Save $9.04 (24%)
Quantity:Qty: 1-9 $27.95/ea
Quantity:Qty: 10+$26.11/ea
Order in the next 0 hr 26 min to ship today. Details
This 1" fabric dome driver has been designed to cater specifically to high-range frequencies above 3000 Hz. It uses magnet shielding which makes it compatible to be used near electronic equipment without causing interference. The SC10n-8 isn't just powerful, it's also capable of delivering a linear frequency response. This is thanks to the special dome coating and ferrofluid-cooled voice-coil, which also allows for high power handling. As such, this driver is not only durable, but also capable of delivering clear, detailed sound. This speaker driver is perfect for shielded medium-sized 2-way combinations and works exceptionally well in surround center speakers and multimedia systems. With a peak power handling of 150 W (with high pass) and nominal power handling of 100 W (with high pass), the Visaton SC10n-8 can deliver the volume you need without distorting your sound.
BrandVisaton
ModelSC10N-8
Part Number292-762
Weight1
Nominal Diameter1"
Cutout Diameter3.34
Tweeter TypeSoft Dome
Power Handling (RMS)100 Watts
Power Handling (MAX)150 Watts
Frequency Response1,000 to 20,000Hz
Sensitivity90dB 2.83V/1m
Voice Coil Diameter0.98"
Resonant Frequency (Fs)1700Hz
Overall Outside Diameter4.09"
Baffle Cutout Diameter3.35"
Depth1.38"
