  • Visaton K64WP-50 2-1/2" Waterproof Full-Range Driver with Plastic Diaphragm 50 Ohm
CLEARANCE Visaton K64WP-50 2-1/2" Waterproof Full-Range Driver with Plastic Diaphragm 50 Ohm
Visaton
Part #292-716
Visaton
Part #292-716
Model: K64WP-50
The Visaton K64WP-50 is a 2.5" full-range speaker. Its design incorporates a plastic basket and diaphragm, making it suitable for outdoor applications and high humidity environments.
  • Rated power of 2W and maximum power of 3W
  • Frequency response range of 200–15000 Hz
  • Temperature range of -40 to 80 °C
  • IP65 protection class when built into a sealed enclosure
  • Designed for outdoor use and high humidity conditions
CLEARANCE $7.98
MSRP: $8.50
Save $0.52 (6%)
Quantity:Qty: 1-9 $7.98/ea
Quantity:Qty: 10+$7.34/ea
32In Stock
The Visaton K64WP-50 is a 2.5" full-range speaker that's been designed with a focus on durability and performance. It features a plastic basket and diaphragm that help it withstand various environmental conditions, including high humidity. This speaker provides a broad frequency response of 200–15000 Hz. It's specifically designed to perform well outdoors and in environments with high humidity levels. Its resilience to weather and UV exposure is a distinct characteristic. The K64WP-50 can function in temperatures as low as -40 °C and as high as 80 °C, making it versatile across various climates. When built into a sealed enclosure, it achieves an IP65 protection class on the front side. The Visaton K64WP-50 has a rated power of 2W and a maximum power of 3W. This compact full-range speaker provides dependable performance while handling the challenges of outdoor applications.
BrandVisaton
ModelK64WP-50
Part Number292-716
Weight0.15
Nominal Diameter2-1/2"
Power Handling (RMS)2 Watts
Power Handling (MAX)3 Watts
Impedance50Ω
Frequency Response200 to 15,000Hz
Sensitivity86dB 2.83V/1m
Voice Coil Diameter0.39"
Resonant Frequency (Fs)300Hz
Overall Outside Diameter2.52"
Baffle Cutout Diameter2.36"
Depth0.76"
