  • Visaton K57FL-8 2-1/4" Waterproof Miniature Driver with Mylar Diaphragm 8 Ohm
Visaton
Part #292-724
Visaton
Part #292-724
Model: K57FL-8
The Visaton K57FL-8 is a 2.2" miniature speaker with a plastic (Mylar) diaphragm and a metal basket. It features a very flat design, making it ideal for signal output in machines and other equipment with limited installation depth.
  • Rated power of 1W and maximum power of 2W
  • Frequency response from 220–16000 Hz
  • Resilience in diverse temperature conditions, from -25 °C to +70 °C
  • Flat design suitable for applications with limited installation depth
  • Comes with IP65 protective system when built into a sealed enclosure
Your Price: $5.98
MSRP: $6.36
Save $0.38 (6%)
Quantity:Qty: 1-9 $5.98/ea
Quantity:Qty: 10+$5.50/ea
Order in the next 15 hr 19 min to ship today. Details
28In Stock
The Visaton K57FL-8 is a 2.2" miniature speaker designed to deliver clear audio output in environments where installation depth is restricted. Equipped with a Mylar diaphragm and a metal basket, this speaker is not only durable but also provides good sound reproduction. Its flat design makes it suitable for integration into machines and equipment that require signal output in a space-efficient manner. Despite its compactness, the K57FL-8 doesn't compromise on sound quality, with a frequency response ranging from 220–16000 Hz. The speaker boasts a rated power of 1W and a maximum power of 2W, promising reliable performance. Its ability to withstand temperatures from -25 °C to +70 °C underlines its versatility and adaptability to various conditions. The Visaton K57FL-8 is designed with an IP65 protective system when housed in a sealed enclosure, offering protection against dust and low-pressure water jets. With connections via solder joints, it ensures a secure and effective audio setup. This speaker is a dependable choice for those looking for a compact yet efficient sound solution.
BrandVisaton
ModelK57FL-8
Part Number292-724
Nominal Diameter2-1/4"
Power Handling (RMS)1 Watts
Power Handling (MAX)2 Watts
Frequency Response220 to 16,000Hz
Sensitivity83dB 2.83V/1m
Voice Coil Diameter0.55"
Resonant Frequency (Fs)350Hz
Overall Outside Diameter2.24"
Baffle Cutout Diameter2.04"
Depth0.35"
MONSTER DEAL
OF THE WEEK
$129.49 EACH
SAVE $14
Dayton Audio HTA20 20 Watt Integrated Stereo Hybrid Tube Amplifier With USB-DAC and Bluetooth 5.0
