  • Visaton K50WP-8 2" Full-Range Water Resistant Speaker 8 Ohm
Visaton
Part #292-538
Visaton
Part #292-538
Model: K50WP - 8
Choose the 8-ohm 2915 K50WP 2" full-range speaker from Visaton for outdoor applications where direct moisture, high humidity, and space limitations are a factor.
  • IP65 rated speaker for outdoor use
  • UL 94-rated ABS basket
  • One-piece mylar cone and surround
Your Price: $6.11
MSRP: $7.99
Save $1.88 (24%)
Quantity:Qty: 1-9 $6.11/ea
Quantity:Qty: 10-24 $5.93/ea
Quantity:Qty: 25+$5.67/ea
Order in the next 10 hr 1 min to ship today. Details
Only 4 In Stock
More due on 12/20/2024
Visaton's 2915 K50WP 2" full-range speaker features a unique weather and UV-resistant design. A UL 94-rated ABS basket is used in conjunction with a one-piece mylar cone and surround. This allows the K50WP to be used in outdoor audio applications where water and high humidity are a factor. When used in a sealed enclosure, the front of this speaker conforms to the IP65 water resistance rating (meaning it can withstand direct moisture).
Note: For maximum power handling, a 1st-order 300 Hz high-pass filter is recommended.
BrandVisaton
ModelK50WP - 8
Part Number292-538
Weight0.123
Nominal Diameter2"
Power Handling (RMS)2 Watts
Power Handling (MAX)3 Watts
Frequency Response180 to 17,000Hz
Sensitivity84dB 2.83V/1m
Voice Coil Diameter0.39"
Resonant Frequency (Fs)300Hz
Maximum Linear Excursion (Xmax)0.25mm
Cone MaterialPoly / Mylar Diaphragm
Overall Outside Diameter1.97"
Baffle Cutout Diameter1.81"
Depth0.63"
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
