  • Visaton K50 SQ 2" Speaker 8 ohm
Visaton
Part #292-543
Visaton
Part #292-543
Model: K50
The K50 8 ohm 2" polypropylene cone full-range driver from Visaton produces natural and articulate frequency response in the vocal range, this driver is perfect for small electronic projects.
  • 500 to 10,000 Hz frequency response designed specifically for vocal reproduction
  • Mylar cone withstands UV and moisture for use outdoors
  • Foam front gasket ensures a water tight seal to enclosures
  • Extremely uniform off axis frequency response
Your Price: $7.06
MSRP: $9.99
Save $2.93 (29%)
Quantity:Qty: 1-9 $7.06/ea
Quantity:Qty: 10-24 $6.85/ea
Quantity:Qty: 25+$6.56/ea
17In Stock
Visaton's K50 SQ 2" full-range speaker features a unique weather and UV-resistant design. When used in a sealed enclosure, the front of this speaker conforms to the IP65/67 water resistance rating (meaning it can withstand direct moisture). The K50's specialty is vocal reproduction with great output in the 500 to 5,000 Hz range, making this the perfect driver for use in small projects designed for use outdoors.
BrandVisaton
ModelK50
Part Number292-543
Weight0.11
Nominal Diameter2"
Bolt Circle Diameter2.22
Power Handling (RMS)2 Watts
Power Handling (MAX)3 Watts
Frequency Response250 to 10,000Hz
Sensitivity83dB 2.83V/1m
Voice Coil Diameter0.55"
Resonant Frequency (Fs)480Hz
DC Resistance (Re)7.3Ω
Mechanical Q (Qms)6.42
Electromagnetic Q (Qes)7.32
Total Q (Qts)3.42
Compliance Equivalent Volume (Vas)0.002ft³
Mechanical Compliance of Suspension (Cms)0.27mm/N
BL Product (BL)1.12T·m
Surface Area of Cone (Sd)12.5cm²
Cone MaterialPoly / Mylar Diaphragm
Overall Outside DiameterSquare 2"
Baffle Cutout Diameter1.75"
Depth0.75"
Sealed Volume0.01ft³
Sealed F3349.5Hz
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
