  • Visaton FRS7S-8 2-1/2" Waterproof Paper Cone Full-Range Driver 8 Ohm
Visaton
Part #292-698
Visaton
Part #292-698
Model: FRS7S-8
The Visaton FRS7S-8 is a 6.5 cm (2.5") full-range speaker providing a balanced frequency response and excellent highs. Ideal for use in a variety of applications, this speaker excels in delivering high-quality output and is perfectly designed for DIY projects and column speakers.
  • 2.5" full-range speaker with a balanced frequency response
  • Suitable as a built-in speaker for music reproduction or as a driver for column speakers
  • Very low resonance frequency for clear and deep sound
  • Waterproof membrane and robust metal design, temperature resistant up to 100°C
  • Rated power of 8W, with a maximum power of 15W
  • Impressive frequency response of 120–20000 Hz
Your Price: $12.98
MSRP: $15.12
Save $2.14 (14%)
Quantity:Qty: 1-9 $12.98/ea
Quantity:Qty: 10+$11.94/ea
8In Stock
The Visaton FRS7S-8 is a durable 2.5" full-range speaker, notable for its balanced sound and strong high frequencies. It's ideal for use as a built-in speaker for music and as a component in column speakers. Its low resonance frequency ensures clear, deep sound, while its robust design — including a waterproof membrane and temperature resistance — adds to its reliability. With a power range of 8W to 15W and a frequency response of 120–20000 Hz, the FRS7S-8 is a versatile choice for a wide range of audio applications.
BrandVisaton
ModelFRS7S-8
Part Number292-698
Weight0.45
Nominal Diameter2-1/2"
Power Handling (RMS)8 Watts
Power Handling (MAX)8 Watts
Frequency Response120 to 20,000Hz
Sensitivity84dB 2.83V/1m
Voice Coil Diameter0.55"
Resonant Frequency (Fs)150Hz
Overall Outside Diameter2.62"
Baffle Cutout Diameter2.40"
Depth1.26"
