  • Visaton FR8 3.3" Full-Range Speaker 4 Ohm
4 Questions, 8 Answers or
Visaton
Part #292-639
Visaton
Part #292-639
Model: FR8
Choose the FR 8 3.3" 4 ohm full-range speaker from Visaton for sound applications where space is critical and high fidelity, wide bandwidth output is needed. 4 ohm impedance.
  • Water resistant paper cone with cloth surround for smooth frequency response
  • Common size stamped steel frame with front mounted cardboard gasket
  • Lightweight paper cone delivers smooth high frequency response
  • Smooth response up to 20,000 Hz with excellent dispersion
Your Price: $10.91
MSRP: $14.99
Save $4.08 (27%)
Quantity:Qty: 1-9 $10.91/ea
Quantity:Qty: 10-24 $10.58/ea
Quantity:Qty: 25+$10.13/ea
Out of Stock
Visaton's 4 ohm FR 8 3.3" paper cone HiFi full-range driver features smooth frequency response from 130 to 20,000 Hz, making it an ideal speaker for use in surround sound satellite speakers, multimedia speakers, exhibit display speakers, and even ceiling speakers for public transportation. Thanks to a water resistant paper cone, this driver is even suitable in damp and high humidity locations.
A rugged stamped-steel frame and cloth surround ensures durability and longevity. With natural full-range response and wide dispersion, the FR 8 is an incredible value. The 4-ohm impedance of the FR 8 is great for series pairs used in MTM and center channel speakers, or for use in mobile and marine audio systems.
BrandVisaton
ModelFR8
Part Number292-639
Weight0.55
Nominal Diameter3"
Bolt Circle Diameter3.38
Power Handling (RMS)10 Watts
Power Handling (MAX)15 Watts
Frequency Response130 to 20,000Hz
Sensitivity86dB 2.83V/1m
Voice Coil Diameter0.59"
Resonant Frequency (Fs)150Hz
DC Resistance (Re)3.4Ω
Mechanical Q (Qms)5.38
Electromagnetic Q (Qes)1.3
Total Q (Qts)1.04
Compliance Equivalent Volume (Vas)0.021ft³
Mechanical Compliance of Suspension (Cms)0.704mm/N
BL Product (BL)1.98T·m
Diaphragm Mass Inc. Airload (Mms)1.6g
Surface Area of Cone (Sd)24.5cm²
Cone MaterialTreated Paper
Surround MaterialCloth
Overall Outside Diameter3.77" across mounting holes; 3.14"
Baffle Cutout Diameter3"
Depth1.45"
Sealed Volume0.05ft³
Sealed F3138.2Hz
Vented Volume0.05ft³
Vented F3108.2Hz
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
