  • Visaton Electro Dynamical Exciter 10W 4 Ohm EX45S-4
CLEARANCE Visaton Electro Dynamical Exciter 10W 4 Ohm EX45S-4
VisatonPart # 292-732
Model: EX45S-4
1 Question, 1 Answer or
he Visaton EX45S-4 is an electro-dynamical exciter, designed to stimulate bending waves on plates. This unit provides a unique alternative to traditional speakers, offering the ability to generate sound in applications where normal speakers aren't an option due to aesthetic or environmental considerations.
  • Maximum power of 10W
  • Electro-dynamical exciter that stimulates bending waves on plates
  • Ideal for applications where conventional speakers aren't suitable
  • Can operate within a temperature range of -25 °C to +70 °C
  • Can be attached to the surface of the plate by gluing or screwing
CLEARANCE $25.00
MSRP: $42.91
Save $17.91 (42%)
18 In Stock
We'll send you an email when Visaton Electro Dynamical Exciter 10W 4 Ohm EX45S-4 is back in stock or available for preorder.
The Visaton EX45S-4 is an electro-dynamical exciter, specifically designed to stimulate bending waves on plates for its output. Unlike conventional speakers, this unit can generate sound in a variety of situations where traditional speakers may not be suitable, such as in visually sensitive settings, or areas requiring protection against environmental conditions or vandalism. The EX45S-4 can be attached to the surface of the plate, either by gluing or screwing, allowing for a degree of flexibility in its installation. With a voice coil diameter of 25.4 mm and a maximum power of 10W, this exciter is capable of producing significant acoustic energy. The device can operate within a temperature range of -25 °C to +70 °C, making it suitable for various environmental conditions. Connections are made via 4.8 x 0.8 mm (+) and 2.8 x 0.8 mm (-) terminals. The Visaton EX45S-4 offers a distinct, versatile, and robust solution for sound generation in a variety of challenging applications.
BrandVisaton
ModelEX45S-4
Part Number292-732
Weight0.15
Power Handling (RMS)10 Watts
