  • Vanco Dual Gang Reversible Bulk Cable Wall Plate Almond
CLEARANCE Vanco Dual Gang Reversible Bulk Cable Wall Plate Almond
Vanco
Part #261-166
Vanco
Part #261-166
Model: 120621X
Unique to this wall plate is a removable cable plate hood which may be installed on the outside of the wall for cable protection, or inside of the wall for use as a flush cable port that creates a custom hidden in-wall cable management system.
  • Perfect installation piece for plasma and LCD TVs
  • Designed to fit standard electrical J-boxes
  • Accommodates HDMI, DVI, VGA, and audio cables
  • Removable and reversible hood design
  • Unique two-piece wall plate design provides for easier installation
CLEARANCE $6.99
MSRP: $7.99
Save $1.00 (13%)
21In Stock
Bulk cable wall plates save installation time and money while providing a clean finished appearance. Unique to this wall plate is a removable cable plate hood which may be installed on the outside of the wall to provide maximum cable protection and to keep debris from falling into the wall. Alternatively for flat panel TV installations, where space between the wall and the TV is at a minimum, the cable hood may be mounted inside of the wall for use as a flush cable port that creates a custom hidden in-wall cable management system.
Note: A low voltage mounting bracket is needed to install this wall plate. See related items for the appropriate bracket.
BrandVanco
Model120621X
Part Number261-166
UPC741835079747
Weight0.15
FinishAlmond
SizeDual Gang
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
