True Wireless TWS Bluetooth 5.0 In-Ear Headphones/Earbuds The True Wireless Bluetooth Earbuds provide you complete wireless freedom. Don't sacrifice audio quality for ergonomics; not only do the earbuds provide extreme ease-of-use, but they also sound great. Featuring multi-touch controls for functions such as play/pause, track skip, volume, call assist, and voice assistant, the earbuds give you complete control over your phone's audio. Complete with a rechargeable USB C charging case, the earbuds are ideal for on-the-go use.
Automatically connecting to your Bluetooth device when removed from the charging case, the earbuds are easy to pair without the need to hassle over phone setting menus. Each earbud features multi-touch controls that allow you to access playback and call functions by tapping on the earbuds. Control play/pause, track skip, volume, call assist, and voice assist by tapping on the earbud. Each control has a dedicated tap pattern to access the function.
Bluetooth: Version 5.0
Continuous talk time: 4 hours
Continuous playback time: 4 hours
Impedance: 16 ohms
Frequency range: 20-20,000 Hz
Sensitivity: 101 dB @ 1 kHz
Mic sensitivity: -38 dB @ 1 kHz
Earbud charging time: 1-1/2 hours
Earbud battery capacity: 40 mAh
Charging case charge time: 2-1/2 hours
Charging case connection: USB Type C (5V)
Charging case battery capacity: 300 mAh
Earbud charging cycles case capacity: 2
Charging case weight: 1.1 oz.
Earbud weight (each): 0.16 oz.
The earbuds fit snugly into your ear, perfect for on-the-go listening and communication. The package comes with three sets of silicone ear tips in small, medium, and large sizes so you can find the perfect fit.
A dedicated charging case allows you to use the earbuds on the go without having to worry about needing a wired charging connection. The charging case provides two charging cycles for the earbuds for a total of up to 8 hours of playback time before needing to charge the case. When you place the earbuds back into the charging case, they automatically disconnect from your device's Bluetooth. Each charge via the charging case gives you 4 hours of continuous talk or playback time. The charging case features a USB C connection for quick charging.
Ideal for on-the-go listening, the earbuds are perfect for travel, web meetings, working out, casual listening, and any instance where you need accessible audio and communication abilities without wanting to hassle with wires.
