  • Toslink and Digital Coaxial Audio Extender Over Ethernet (up to 330 ft.)
CLEARANCE Toslink and Digital Coaxial Audio Extender Over Ethernet (up to 330 ft.)
4 Questions, 7 Answers or
Part #180-1142
Part #180-1142
This digital audio extender allows you to extend a digital SPDIF audio signal up to 320 ft. over a single Cat 5E/6 Ethernet cable. The kit includes both the transmitter and receiver as well as a 12 VDC power supply. This device is ideal for digital signage, broadcasting, retail stores, transportation stations, hospitals, classrooms, or other application that needs long distance audio runs without signal quality loss.
  • Extend digital audio signals up to 320 ft through Cat 5E or Cat 6 cable
  • Supports PCM, DTS, and Dolby Digital audio formats
  • Support for dual digital inputs and outputs (1 x coax, 1 x optical)
  • Superior audio integrity over long distances with no loss on signal quality
  • Receiver powered via PoE (power over Ethernet)
  • Includes a transmitter, receiver, and 12 VDC, 1A power supply
Supporting a wide array of popular audio formats such as PCM, DTS, and Dolby Digital, this device delivers high quality audio in up to 96 kHz over long distances. The transmitter and receiver have both an optical and coax connection and the signals can be run simultaneously while maintaining signal integrity. The receiver is powered by the transmitter via PoE (power over Ethernet) function so only one power supply is required.
Audio inputs: Coax, optical, RJ45
Audio outputs: Coax, optical, RJ45
Transmission distance: 100m via Cat 5E/6 cable
Data transmission rate: 12.8 mb/s
DAC sample rate: 96 kHz
Power supply: 12 VDC, 1A
Certifications: FCC, CE, RoHS
Dimensions (each): 2.6" x 2.1" x 1.1"
Part Number180-1142
UPC848864061641
Weight0.9
