  • Topping PA7 Plus Compact Desktop Amplifier with Balanced and Unbalanced Inputs 2x300 Watt
Read 1 Review or
Topping
Part #220-212
Topping
Part #220-212
Model: PA7 Plus
Read 1 Review or
The Topping PA7 Plus is a powerful compact desktop amplifier that delivers 2x300 watts of high-quality audio output. Featuring both balanced and unbalanced inputs, this versatile amplifier is designed to deliver clean, dynamic sound across a wide range of audio systems. With its robust power, sleek design, and easy integration, the PA7 Plus is an ideal choice for those seeking a compact yet potent amplification solution.
  • 2x300 watts of powerful output for robust sound performance
  • Balanced XLR/TRS and unbalanced RCA inputs
  • Low enough distortion to rival any DAC
  • Volume bypass allows the PA7 Plus to cede volume control to a preamp
  • 12V trigger allows for an easy on/off procedure
Your Price: $549.00
MSRP: $783.99
Save $234.99 (30%)
Out of Stock
Advertised price subject to change due to tariff uncertainty
Alert Me When Available
The Topping PA7 Plus is a compact desktop amplifier designed to deliver impressive power and audio clarity. With an output of 2x300 watts, this amplifier is capable of driving a wide variety of speakers with authority, making it suitable for both bookshelf and tower speaker setups. The PA7 Plus brings your music to life with dynamic, punchy sound that is both powerful and detailed.
This amplifier features both balanced (XLR/TRS) and unbalanced (RCA) inputs, allowing you to connect it to a range of audio sources, from DACs and preamps to other components. The dual-input design provides flexibility in your setup, accommodating different connection preferences and equipment types. The result is a clean, high-quality audio signal that preserves the integrity of your music.
Utilizing high-efficiency Class D amplification, the PA7 Plus delivers robust sound with such minimal distortion as to rival any DAC, meaning that every note is reproduced with precision and clarity. Its compact and sturdy design makes it an ideal fit for any desktop or bookshelf setup, while the sleek, minimalist interface offers straightforward operation. The PA7 Plus combines power, performance, and practicality, making it a top choice for those looking to enhance their audio system with a reliable and potent amplifier.
BrandTopping
ModelPA7 Plus
Part Number220-212
Weight7.28
