CLEARANCE Timpano Audio TPT-T2500-10 D2 10" Cast Frame DVC Subwoofer 2 Ohms Per Coil
- 23.5 mm Xmax and 1,000 watts RMS ensures high output capability for extreme SPL
- 3" diameter American made voice coil can withstand extreme heat and abuse
- Extensive venting rapidly dissipates excess heat for low power compression and excellent reliability
- Double layer spider and large high roll surround allows high excursion for maximum displacement
- Rugged cast aluminum frame and deep motor provides plenty of clearance when driven to the limit
- Dual 2-ohm voice coil gives you the flexibility to maximize the output of most amplifiers
We'll send you an email when Timpano Audio TPT-T2500-10 D2 10" Cast Frame DVC Subwoofer 2 Ohms Per Coil is back in stock or available for preorder.
