  • Timpano Audio TPT-MD12 PRO 12" Midrange Speaker 8 Ohm
Timpano Audio
Part #294-3332
Timpano Audio
Part #294-3332
Model: TPT-MD12 PRO
Timpano Audio's TPT-MD12 PRO 12" midbass speaker is a great choice for adding some high output midbass to professional and automotive sound systems. With a large vented ferrite magnet and 3" voice coil, this driver is ideal for use in high output applications. Capable of handling a massive 400 watts RMS and with a sensitivity of 101 dB, the TPT-MD12 PRO is designed to deliver continuous high SPL midbass output.
  • Broad 55-3,000 Hz frequency range for ultimate flexibility
  • Massive 101 dB sensitivity for maximum output with minimal power
  • Large vented ferrite motor for increased output and power handling
  • Strong and lightweight cast aluminum frame
  • 0.38 total Q for sealed or vented enclosures
Your Price: $119.95
MSRP: $149.94
Save $29.99 (20%)
Order in the next 5 hr 31 min to ship today. Details
Only 4 In Stock
The TPT-MD12 PRO 12" midbass speaker from Timpano Audio is built like a professional midbass, but has been designed for use in the mobile audio market. With a naturally damped paper cone and dual roll cloth surround, this driver keeps resonances under control for natural response. The 3" voice coil and powerful vented magnet are designed to allow high sensitivity and increased power handling. Due to a Qts of 0.38, this will work perfectly in vented or sealed enclosures.
BrandTimpano Audio
ModelTPT-MD12 PRO
Part Number294-3332
UPC611056239001
Weight17.3
Nominal Diameter12"
Power Handling (RMS)400 Watts
Power Handling (MAX)800 Watts
Frequency Response55 to 3,000Hz
Sensitivity101dB 2.83V/1m
Voice Coil Diameter3"
Resonant Frequency (Fs)51.7Hz
DC Resistance (Re)5.5Ω
Mechanical Q (Qms)10.7
Electromagnetic Q (Qes)0.39
Total Q (Qts)0.38
Compliance Equivalent Volume (Vas)3.4ft³
Mechanical Compliance of Suspension (Cms)0.21mm/N
BL Product (BL)14.3T·m
Diaphragm Mass Inc. Airload (Mms)45.2g
Surface Area of Cone (Sd)573cm²
Cone MaterialPaper
Surround MaterialCloth
Sealed Volume1ft³
Sealed F3108.1Hz
Vented Volume2.25ft³
Vented F355Hz
MONSTER DEAL
OF THE WEEK
$34.98 EACH
SAVE 22%
Lepai LP-168HA 2.1 2x40W Mini Amplifier + 1x68W Sub Output
