The TERK AM/FM Tower is a high-performance antenna that provides superior radio reception. The Tower’s built-in amplifier strengthens weak and distant signals offering greater control over the quality of your reception. Its Air Coil™ technology isolates the AM and FM elements from each other increasing radio reception and minimizing static and noise. The Tower can be used as an omni-directional or directional antenna. When placed vertically, it equally receives signals from all different directions; when placed flat, the antenna becomes directional and can be pointed at distant stations for better reception. With the emergence of new technology in radio broadcasting, the Tower was designed to be digital broadcast radio ready.
Specifications: • FM Section: Reception Pattern: Omni-directional • Frequency Range: 88 to 108MHz • Amplifier Gain: 10dB min • Gain Control: 20dB min • FM Output Impedance: 75 Ohm • VSWR (Voltage Standing Wave Ratio): <1.2:1 AM Section: Frequency Range: 540 to 1700 KHz • Gain: +15dB min • AM Output Impedance: 300 Ohm, Twin-lead • Dimensions: 3.25" W x 17" H x 3.5" D.
