  • Techflex 3/4" Expandable Sleeving 25 ft. Neon Green
CLEARANCE Techflex 3/4" Expandable Sleeving 25 ft. Neon Green
1 Question, 1 Answer or
Techflex
Part #082-374
Techflex
Part #082-374
Model: PT4NG25-C
Flexo is a strong expandable sleeving that not only provides a professional look but also protects cables, wires and hoses from abrasion, cuts and ultra-violet light.
  • Professional look for custom cable assemblies
  • Bundles cables and organizes wires
  • Easy to install, lightweight and flexible
  • Abrasion, chemical and U/V resistant
  • Wide operating temperature
  • Available in a variety of colors and sizes
CLEARANCE $19.98
MSRP: $32.99
Save $13.01 (39%)
Quantity:Qty: 1-3 $19.98/ea
Quantity:Qty: 4+$17.71/ea
Order in the next 4 hr 18 min to ship today. Details
1In Stock
Techflex Flexo is a strong expandable sleeving that not only provides a professional look but also protects cables, wires and hoses from abrasion, cuts and ultra-violet light. Due to its expandable nature, the braiding will easily slip over large connectors and then "form-fit" over cables for quick and easy installations. Because it is available in a variety of colors and sizes, it can be used to "color code" wires for easy identification. It is braided from .010" monofilament polyester yarn that can withstand temperature extremes from -103° F to +257° F, making it perfect for automotive applications. Flexo can be terminated using electrical tape, wire ties or heat shrink. For a professional look, and to slide over large connectors, we recommend using our 3-to-1 Ratio heat shrink which is also available in a variety of colors and sizes. Braiding must be cut with a hot knife to prevent unraveling and has a melting temperature of +446° F. Sold in 25 ft. lengths.
Specifications: • Size I.D.: 3/4" • Size Range (min~max): 1/2"~1-1/4" • Color: Neon Green.
BrandTechflex
ModelPT4NG25-C
Part Number082-374
UPC738854005659
Weight0.37
ColorNeon Green
Nominal I.D.0.75"
Sleeving TypeExpandable
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
