  • Tang Band W2-803SM 2" Extended Range Speaker Driver
Tang Band
Part #264-805
Tang Band
Part #264-805
Model: W2-803SM
A small 2" drive unit useable as a mid-tweeter or extended-range midbass. Features include a silver poly cone, ABS basket, solid aluminum phase plug, shielded neodymium motor, s-shaped surround, and venting under the spider.
Your Price: $44.98
MSRP: $58.99
Save $14.01 (24%)
Quantity:Qty: 50+$44.98/ea
Out of Stock
Special Order Item ships in 90-120 days
Alert Me When Available
A small 2" drive unit useable as a mid-tweeter or extended-range midbass. Features include a silver poly cone, ABS basket, solid aluminum phase plug, shielded neodymium motor, s-shaped surround, and venting under the spider. Great for A/V, multimedia, automotive, or multi-driver hi-fi use.
BrandTang Band
ModelW2-803SM
Part Number264-805
UPC844632009716
Weight0.3201
Nominal Diameter2"
Power Handling (RMS)8 Watts
Power Handling (MAX)16 Watts
Frequency Response160 to 20,000Hz
Sensitivity85dB 2.83V/1m
Voice Coil Diameter0.75"
Resonant Frequency (Fs)160Hz
DC Resistance (Re)3.6Ω
Voice Coil Inductance (Le)0.04mH
Mechanical Q (Qms)3.56
Electromagnetic Q (Qes)0.46
Total Q (Qts)0.4
Compliance Equivalent Volume (Vas)0.008ft³
Mechanical Compliance of Suspension (Cms)1.05mm/N
BL Product (BL)2.69T·m
Surface Area of Cone (Sd)13cm²
Cone MaterialPoly
Overall Outside Diameter2.24"
Baffle Cutout Diameter2.04"
Depth1.35"
Sealed Volume0.01ft³
Sealed F3338.1Hz
Vented Volume0.015ft³
Vented F3137Hz
MONSTER DEAL
OF THE WEEK
$14.98 EACH
SAVE 25%
Dayton Audio Boost Mini Portable Bluetooth Speaker Black
