Talent iClaw Mic or Music Stand Holder for Apple iPadiPads are changing the way musicians read standard sheet music, replacing recording workstations, and in some cases acting as mixers. Talent has created what could be the ultimate accessory for musicians that use iPads with the iClaw™ clamp on microphone and music stand holder for the Apple iPad®.
Talent's iClaw™ is designed using durable ABS construction and features molded claws (sets for the original iPad, 2nd and 3rd generation iPads, iPad Mini, Mini 2, Mini 3, Air and Air 2) that securely hold your iPad in place on any mic stand, music stand, desk, kitchen cabinet, or virtually any solid surface (up to an inch thick) without leaving scratches. It can even attach to most automotive head rests, making it perfect for entertaining kids in the backseat—you will definitely appreciate it on long trips!
Adjustability is the iClaw™ most important attribute. Most iPad mounting systems only allow slight adjustments and force you to use your iPad however the manufacturer saw fit. The iClaw™ allows ±5° of final adjustment tilt in any direction, rotates 360°, and places your iPad on a 6.3" long aluminum telescopic pole that enables a shallow or extended profile and unlimited tilt in any direction.
Last, but not least, the clamp-on assembly is removable so that you can mount your iPad directly to a microphone stand using the 5/8"-27 TPI socket, while still retaining the ±5° of final adjustment tilt in any direction and 360° rotate-ability.
Get the most out of your iPad on-stage, at home, in the car, or just about anywhere you imagination leads you, with the Talent iClaw™.
Note: Many customers purchased the iClaw before iPad Air 2 and Mini 2 were introduced. Talent is dedicated to customer satisfaction and offers these mounting clips for the iClaw at no cost. Please feel free to contact a Customer Service Representative 1-800-338-0531 to receive a free set of clips for your iPad Air 2 or Mini 2. Not compatible with iPad 7.
*Note: The Talent iClaw does not include an iPad, music stand, or microphone stand.
