  • USB Podcast & Streaming Condenser Microphone with Headphone Output and Volume Control
CLEARANCE USB Podcast & Streaming Condenser Microphone with Headphone Output and Volume Control
Talent Sound & LightingPart # 233-094
Model: USB Pro
The Talent USB-PRO professional microphone provides a great, rich, full range sound. The high quality USB cardioid condenser microphone acts not only as your analog to digital (ADC) interface but also as a digital to analog converter (DAC). The built in monitor mix control allows you to monitor your recordings latency free. With a headphone output and volume control, monitor directly off of your recording software without the need of a separate interface. The USB-PRO is perfect for recording vocals, streaming, voice-overs, podcasting, and gaming.
  • Headphone output and volume control
  • Microphone mix control for latency free monitoring
  • 24 bit / 96 kHz sampling rate provides great recording quality
  • Operates as a DAC as well as a ADC with Windows and Mac operating systems, driver-free
  • Great for streaming, recording, gamers, podcasters, and daily vocal use
CLEARANCE $26.10
MSRP: $163.99
Save $137.89 (84%)
75 In Stock
We'll send you an email when USB Podcast & Streaming Condenser Microphone with Headphone Output and Volume Control is back in stock or available for preorder.
Order in the next 2 hr 19 min to ship today. Details
The high class Talent USB-PRO professional USB cardioid condenser microphone provides a great, rich, and detailed full range sound. Integrated with headphone output and a monitor mix control, the microphone is great for general recording purposes, gamers, podcasters, and daily vocal use.
A built-in monitor mix control is used to control the "mix" between the direct microphone signal and the output of your recording software. This feature allows for latency free monitoring. By turning the top knob counter-clockwise, you will hear more of the direct microphone signal and less of the signal coming from your DAW. Turning the knob clockwise, you will hear more signal from your computer than from the direct microphone signal. The mix control allows you to find the perfect balance between computer playback and direct signal from the microphone.
The bottom knob on the microphone controls the volume of the headphones. A 3.5 mm stereo headphone jack allows you plug your headphones directly into the microphone. Not only does the microphone act as a high quality analog to digital converter, it also acts as your digital to analog converter. With a high quality sampling rate of up to 24 bit / 96 kHz, the USB-PRO provides a clean, professional, studio-quality recording capability. Compatible with both Mac and PC operating systems, the microphone works with most DAWs and recording software. Eliminating the need for software drivers, the USB-PRO is incredibly easy to set-up with your computer and audio production software.
Package includes the USB-PRO microphone, high-class metal microphone holder, desktop microphone stand, and USB cable (6 ft.).
Specifications: • Pickup pattern: Cardioid • Frequency response: 30 - 18,000 Hz • Sensitivity: -36 dB ±2 dB (0 dB = 1 V/Pa at 1 kHz) • Maximum input SPL: 130 dB (at 1 kHz, 1% THD) • Microphone sampling rate: 44.1, 48, 88.2, 96 kHz @ 16 bit or 24 bit • Playback sampling rate: 44.1, 48 kHz @ 16 bit • Output: USB and 3.5 mm stereo jack • Operating system compatibility: Mac OSX and Windows.
ADC Specifications: •THD +N: 0.01% • SNR: 89 dB • Dynamic range: 89 dB.
DAC Specifications: • THD+N: 0.005% • SNR: 96 dB • Dynamic range: 93 dB • Stereo output power: 400 mW.
NOTE: The USB-PRO does not include any software; however, many great software recording solutions are available for little or no cost online. We recommend Audacity as a free, easy, and effective recording program.
BrandTalent Sound & Lighting
ModelUSB Pro
Part Number233-094
UPC848864050522
Weight1.55
Element TypeCondenser
On/Off SwitchNo
Polar PatternCardioid
