  • Talent FGS1 Folding Guitar Stand Black
Talent Sound & LightingPart # 233-114
Model: FGS1
Whether you've just started learning to play, or you're a seasoned veteran switching guitars on stage, you need Talent guitar stands to support and protect your valuable instrument.
  • Folds flat for easy transport
  • Opens quickly to provide a safe resting place for your guitar
  • No assembly, and no loose parts to become lost
  • Cushioned supports won't harm your guitar's finish
Your Price: $10.39
MSRP: $15.99
Save $5.60 (35%)
We'll send you an email when Talent FGS1 Folding Guitar Stand Black is back in stock or available for preorder.
Estimated back in stock 8/29/2025
Assembled from lightweight, durable steel tubing, the Talent FGS1 guitar stand folds up flat for easy transportation, and built-in locking mechanisms provide fast, easy and secure set-up. The wide stance of the legs keeps the stand stable, while a safe resting place for your guitar is provided by soft foam rubber coverings, protecting both the neck and the guitar body. The height of the neck support is adjustable from 22" to 31", and an additional rubber security strap is included to prevent the guitar from falling forward if it happens to be bumped by a wayward child, overzealous pet, Uncle Bob when he's had one too many, or what have you. The lower yoke folds down for use, and it is fixed and captive, which means no assembly required, no fumbling to try to get the stand together on a dark stage, and best of all - no lost yokes! Perfect for all standard body styles, such as Stratocasters and Les Pauls (not recommended for non-standard bodies like "V" style, Explorer, Kelly, etc.), also great for acoustic, electric/acoustic, bass, and student scale guitars.
Note: we recommend covering or removing the foam rubber padding if using this stand with a guitar featuring a nitrocellulose lacquer finish.
BrandTalent Sound & Lighting
ModelFGS1
Part Number233-114
UPC848864007045
Weight2.55
