  • Talent BXR-1 XLR Bluetooth Audio Receiver with Rechargeable Battery and USB Cable
Talent Sound & Lighting
Part #240-937
Model: BXR-1
The Talent BXR-1 Bluetooth audio receiver provides any pro audio equipment with Bluetooth 5.0 wireless connectivity while retaining great-sounding audio. With an optional -10dB pad, True Wireless Stereo (TWS) functionality, and 10-hour battery life,  the BXR-1 gives you the flexibility to integrate it into any audio setup.
  • Add Bluetooth 5.0 to any equipment with an XLR input
  • Long distance Bluetooth stays connected, even backstage
  • Rechargeable battery with 10 Hours of playtime
  • TWS (True Wireless Stereo) allows you to wirelessly pair 2 units together for stereo sound
  • Optional -10dB pad for compatibility with multiple reference levels
  • FCC certified
Your Price: $49.98
MSRP: $69.99
Save $20.01 (29%)
89In Stock
Mini Modernization
Bring your old pro audio equipment up to date with the Talent BXR-1 Bluetooth Audio Receiver! The BXR-1 is a compact, battery powered, wireless audio solution that enables the functionality of a Bluetooth receiver to any mixer or speaker. With the all-new TWS functionality included with Bluetooth 5.0, you can pair two BXR-1 units together to wirelessly stream stereo audio to your modernized gear!
No strings attached
Providing inputs for musicians equipment when it's unexpected is the bane of existence for the sound engineer. If you know the struggle of running a 50-foot AUX cable or looking around the venue for a USB-C to 3.5mm adapter, you'll appreciate the convenience of the BXR-1 Bluetooth receiver for those unexpected backing tracks, click tracks or even cue tracks. Simply have the musician pair their player to the BXR-1, sit back and enjoy the show!
Stereo Simplicity
The BXR-1 takes advantage of its Bluetooth 5.0 chipset with all-new TWS (True Wireless Stereo) functionality. TWS is a feature that allows you to share stereo signal from your Bluetooth source between two BXR-1 units without the need of a stereo breakout cable or unsightly linking cables between your loudspeakers. Using the large pairing button with easy-to-see indicator LEDs, you can enable or disable TWS as needed, meaning you'll be prepared for anything out of left (and right) field.
No Charge? No Problem
Sometimes the night goes on much later than you expected and after breaking down all your equipment and packing it up, charging a battery is the last thing on your mind. The BXR-1 can play while it is being charged through the MicroUSB port with minimal noise and fuss!
...And Then Some
If your signal is already loud enough by the time it hits your mixer or loudspeaker, the BXR-1 can attenuate the signal by a total of -10dB with the built-in pad. The switch to disable or enable the pad is easily accessible on the front of the unit, not hidden inside the chassis. No need to find a safety pin to reach the hidden switches like other pieces of equipment!
  • Bluetooth version: 5.0
  • Battery: 3.7V Lithium Polymer 502035
  • Standby current: <50uA
  • Working current: ≥30mA
  • Temperature range: -40° F to 176° F
  • Wireless transmission range: 10m (33 ft.)
  • Frequency response: 20 to 20,000 Hz
  • Sensitivity: -80 dBm<±0.1% BER
  • Bluetooth frequency: 2.4 Ghz-2.48 Ghz
  • Signal to noise: ≥75 dB
  • Distortion: ≤0.1%
  • Charge method/port: 5 VDC Micro USB
  • Stand by: Approximately 50 days
  • Working time: Approximately 10 hours
  • Size: 1.32" D x 1.08" H x 4.88" L (33.4 x 27.5 x 124 mm)
BrandTalent Sound & Lighting
ModelBXR-1
Part Number240-937
UPC848864070100
Weight0.45
MONSTER DEAL
OF THE WEEK
$45.98 EACH
SAVE $12
Dayton Audio KABD-250 2 x 50W All-in-one Amplifier Board with DSP and Bluetooth 5.0 aptX HD
