  • Talent 4CX-3M 4 Connector 3-Pin XLR Extender Over CAT5 - Male
CLEARANCE Talent 4CX-3M 4 Connector 3-Pin XLR Extender Over CAT5 - Male
Talent Sound & Lighting
Part #183-408
Model: 4CX-3M
Consolidate your wire and make cable clutter a thing of the past. The Talent 4CX-3M allows you to send XLR or DMX signals through a single CAT5 or greater cable up to 325 feet.
  • Keep your cables tidy and organized by reducing the number of cables used
  • Connect up to 4 XLR cables for maximum convenience
  • Easily connect an Ethercon CAT5 or greater cable for maximum durability
  • Perfect for easy setup and tear down on stage
  • Able to send a signal up to 325 feet for ultimate flexibility
Ditch the old cable snake and upgrade with Talent!
Remove clutter from your cable runs by consolidating 4 XLR/DMX Channels into a single CAT5 ethernet cable with the Talent 4PXR Series of XLR extenders. Compatible with digital and analog signals, as well as DMX lighting control signals, this modular system can help save costs and shorten setup time!
Durable Design
High-impact ABS and steel construction
Quality XLR Connectors
High-quality XLR connectors on every model
CAT5 Outputs
Robust CAT5 connector provides durability and prevents accidental disconnections
Phantom Power
Delivers phantom power to devices that require it
All you need
The Talent CAT5-XLR Extenders give you confidence in the connections you need to put on a show. Send and receive signals with minimal loss through high-quality XLR and ethercon-type connectors. Carry the convenience to and from the stage through easily manageable and affordable CAT5 cables!
All you want
The 4PX Series consists of 3-Pin Male and Female XLR boxes and pigtails, and 5-Pin Male and Female XLR boxes for any situation you can think of whether you're using analog audio, digital audio, or even DMX lighting control signal! Talent provides a pigtail version of these boxes in the 4CX series of CAT5-XLR Extenders for on-the-go setups.
Shop All CAT5-XLR Extenders
Expand on top of the 4CX-3M with the rest of the Talent CAT5-XLR Extenders to create a customized distribution network.
Talent 4PX-3M
4 Male XLR Ports
1 CAT5 Output
5.6" x 2.1" x 1.65"Shop Now
Talent 4PXR
4 Male/Female XLR Ports
2 CAT5 Output
20" x 5.5" x 3.75"Shop Now
Talent 4CX-3F
4 Female XLR Cables
1 CAT5 Output
4.5" x 2.5" x 2.25"Shop Now
Talent 4PX-3F
4 Female XLR Ports
1 CAT5 Output
Review Title
"Excellent device for the money!!"
- Chunni K.
BrandTalent Sound & Lighting
Model4CX-3M
Part Number183-408
UPC848864065328
Weight0.75
MONSTER DEAL
OF THE WEEK
$189.00 EACH
SAVE 21%
Dayton Audio SPA250DSP 250W Subwoofer Plate Amplifier with DSP
