BUYOUT TC-6024 6-1/2" Treated Paper Cone Woofer with Foam Surround 4 Ohm
Factory Buyouts
Part #299-2196
Factory Buyouts
Part #299-2196
This heavy duty 4 ohm 6-1/2" woofer uses a light-weight cone combined with a massive magnet to provide impressive efficiency for a driver this size. With extensive venting through the back plate this driver is capable of high output with minimal power compression.
- Extensive venting through the back plate to minimize power compression
- Bumped back plate and raised spider to maximize mechanical excursion
- Powerful motor for precise control and high efficiency
- Naturally damped paper cone and foam surround keeps resonances under control
We'll send you an email when TC-6024 6-1/2" Treated Paper Cone Woofer with Foam Surround 4 Ohm is back in stock or available for preorder.
