  • Switchcraft 226 1/4" Mono 90 degree Plug Nickel
Switchcraft
Part #093-128
Switchcraft
Part #093-128
Model: 226PKG
Switchcraft's 1/4" right angle mono plugs have one-piece tip rods for added strength and durability. Features include solder terminals and a shielded nickel handle.
  • 3-piece assembly
  • All metal exterior construction
  • Rugged cable clamp isolates pulling and twisting strains
  • Right-angle handle minimizes space required behind equipment.
  • Large terminals accept up to 16 AWG wiring (cables up to 0.25" diameter)
Your Price: $5.80
MSRP: $12.09
Save $6.29 (52%)
Quantity:Qty: 1-99 $5.80/ea
Quantity:Qty: 100-249 $5.51/ea
Quantity:Qty: 250+$5.34/ea
Only 108 In Stock
Switchcraft's 1/4" right-angle mono plugs are designed for OEMs and users of commercial phone plugs. The plugs offer large terminals for easy wiring, and only three pieces to assemble - handle, insulator, and finger/housing assembly - and feature rugged reliability for stable, long-term, trouble-free operation. At only a 1/2" wide, these plugs are ideal for crowded, multi-channel panels. The tip, rod, and handle are all nickel-plated copper alloy. Right-angle handle minimizes space required behind equipment. Rugged cable clamp isolates pulling and twisting strains. Knurled handles allows for a positive grip during connect/disconnect. Features include solder terminals and a shielded nickel handle. Mfg. #226. Specifications: • Housing/sleeve: Nickel-plated • Tip terminal: Tin-plated copper alloy • Sleeve (clamp) terminal: Tin-plated steel • Insulation: Thermoplastic • Dielectric withstanding voltage: 500 VAC • Insulation resistance: 50,000 Mohms minimum (initial) • Operating temperature: -20°C to +65°C.
BrandSwitchcraft
Model226PKG
Part Number093-128
UPC844632071713
Weight0.1
ConductorsMono TS
GenderMale / Plug
Mounting TypeCable Mount
MONSTER DEAL
OF THE WEEK
$29.98 EACH
SAVE 25%
Talent SB16-32 Stage Boss 32.5 ft. 16/3 Multi-Outlet Commercial Grade Extension Cord with 7 AC Sockets
