  • Stereo Line level Amplifier with 12 VDC 2A AC Adapter
CLEARANCE Stereo Line level Amplifier with 12 VDC 2A AC Adapter
Parts ExpressPart # 180-891
Read 1 Review or
Add extra, or control volume from any analog line output component before it goes into the main amp or into headphones with this audio line level booster.
  • Volume control enables you to increase to the right amount of volume without over saturation
  • On/off switch enables you to cut the volume all the way off
  • Rear red light for power status
  • Small 2" x 3.25" x 3/4" takes up very little room
  • Clean volume boost with only 0.01% THD+N
  • Perfect for extending volume control to buried powered subwoofers
Extra Volume for Low Output Sources
This incredible device is designed to boost the volume from your audio sources, ensuring that you never miss a beat. Simply connect your smartphone, tablet, or any other device with a headphone or line output jack to this preamplifier and experience a significant increase in volume to headphones or final amplifier stage. No more straining to hear your favorite music, podcasts, or movies from weak line output signal. With this stereo line level amplifier, you can enjoy crystal clear audio at the perfect volume. It's like having a personal audio assistant that ensures you never miss a single detail.
Extend or Add a Volume Control
But that's not all - this preamplifier also doubles as a volume control with an on/off switch so you're able to add or extend your output levels. Now you'll have complete control over the sound output. You can easily adjust the volume to your preferred level, enhancing your listening experience without any hassle. Shut the sound completely off if needed with the built-in switch. This works perfect for high power amplifiers with no Bluetooth and volume control option. Add a Bluetooth receiver (sold separately) and get wireless full power out of your amplifier.
So, why continue to struggle with low volume levels when total control over your sound output is available? Invest in this stereo line level amplifier today and elevate your audio experience to new heights. Say goodbye to constant adjustments and hello to amplified sound quality. It's time to turn up the volume and enjoy your favorite media like never before!
Note: To avoid power on/off pop, turn your amplifier off first or leave the preamp on. Its standby current draw is less than 1 mA with the LED lit. Current draw when it receives a signal is less than 20 mA.
Specifications: • Input Voltage: 8-20 VDC (12 VDC recommended) • DC jack: 2.1 x 5.5 mm tip positive • Max gain: 23 dB @ 3.3 V • Frequency response: 20 to 20,000 Hz • SNR: 83 dB • THD+N: 0.01% • Input and output impedance: 75 ohm • Included power supply output: 12 VDC 2A • Power supply input: 100~240 VAC, 50/60 Hz.
Part Number180-891
UPC848864077192
Weight0.46
