  • Sonic Barrier AB-4 Sound Insulation Absorbing Sheets 31.5" x 19.68" 4 pcs.
Sonic Barrier
Part #268-048
Sonic Barrier
Part #268-048
Model: AB-4
Sonic Barrier AB-4's self-sticking, light weight, high quality foam rubber absorbs unwanted sounds for businesses, homes, and vehicles.
  • Light weight makes it easy to install almost anywhere
  • Peal-n-stick installation eliminates messy glue
  • 5 mm (197 mil) thickness absorbs sounds without taking up a lot of space
  • High quality foam rubber doesn't dry rot like other foam materials
Your Price: $22.98
MSRP: $28.99
Save $6.01 (21%)
Quantity:Qty: 1-3 $22.98/ea
Quantity:Qty: 4+$21.24/ea
This 5 mm foam rubber sound installation material mounts in places that heavier sound dampening materials can't. It's light enough to mount on folding or closet doors to absorb sounds coming from an all-electric heating and air system. Use it on garage doors to help muffle noise from air compressors and other power tools.
If you're tired of trying to eliminate feedback from rooms, large lecture stands, and pulpits try Sonic Barrier AB-4s sound absorbing material. It will absorb those annoying sound reflections you get from hard surfaces. Just cut it to size, peal, and stick it to surfaces that are causing echo.
The high quality foam rubber won't dissolve in high heat environments like other foam materials. This enables you to use it in vehicles, and other environments that normal foam or sponge materials dry out. AB-4's foam rubber is also pick resistant.
Specifications: • Dimensions per sheet: 31.5" L x 19.68" W x 0.2" H (800 x 500 x 5 mm).
BrandSonic Barrier
ModelAB-4
Part Number268-048
UPC848864034904
Weight2.85
