This small phenolic knob puts the perfect finishing touch on your amplifier or other project. Fluted vintage design, measures 0.5" diameter (at base, slightly tapering toward the top) x 0.62" height (12.7 x 15.8 mm). Set screw for use with 6 mm shaft; white indicator stripe.
Maybe you're repairing, restoring, or hot rodding an existing guitar, amplifier, or other electronic equipment. Perhaps you're devising your own unique musical or audio gear from scratch. Any way you slice it, Parts Express has the quality components you need to finish the job right, at prices you can afford.
