  • Simply45 S45-1755P Pass Through RJ45 Shielded Connectors Yellow Tint for 23 AWG Cat6/6a/7/7a STP - 50pc Jar
CLEARANCE Simply45 S45-1755P Pass Through RJ45 Shielded Connectors Yellow Tint for 23 AWG Cat6/6a/7/7a STP - 50pc Jar
Simply45
Part #150-1016
Simply45
Part #150-1016
Model: S45-1755P
Simply45 is the industry-leading brand for RJ45 modular plug innovation and performance solutions. Simply45 S45-1755P 23 AWG Cat6/6a/7/7a STP yellow tinted shielded external ground pass-through RJ-45 connectors have three points for each terminal that ensure a connection every time after crimping with Simply45 ratcheting feed through crimpers.
  • 3-prong pin design with 50µ of true 24ct gold plating for perfect connection every time
  • PoE/PoH rated for high current
  • Compliant with Industry standards ANSI/YIA568.2, 1096-A; ISO/IEC 11801, 60603-7, :1992; FCC8877
  • Yellow tint ensures your using the right connector for shielded internal ground Cat6/6a/7/7a STP solid 23 AWG LAN cables and Cat6/6a/7/7a STP Stranded cables
  • UL94 V0 (IEC 60695-11-10) rated for 10G commercial use and Plenum applications
  • Wires feed through the connector to make it easier to verify correct wiring sequence
  • Limited lifetime warranty from Simply45
CLEARANCE $122.95
MSRP: $153.95
Save $31.00 (20%)
Order in the next 4 hr 23 min to ship today. Details
1In Stock
Simply45 color coded connectors always insures you have the right connector for your various networking cables. If you have a handful of Simply45 shielded connectors, how do you know what connectors go with Cat6/6a/7/7a 23 AWG cable. Look for the yellow tinted ones and you have your answer. The yellow lid on the jar also helps keep the colors identified and separated. The yellow tinted connectors work with wire conductors 1.15 - 1.35mm (0.045" - 0.053"), Max Cable OD 8mm (0.315").
All Simply45 true 24ct gold plated terminals make the perfect connection every time you crimp them with Simply45 ratchet action tools. All other RJ-45 connectors only have two pins per terminal that penetrate the wire jacket during the crimping cycle. If both of the spikes miss going through the jacket you have a bad connection, and you've just waisted a connector. Simply45 RJ-45 connectors have a three-pin design per terminal that guarantees that a pin will penetrate the jacket and make connection with the bare copper wire. The S45-1755P includes a load bar that makes it easier to pass the wires through and extra protection to prevent the plug from shorting out.
Simply45 RJ-45 connectors are compliant with industry standards and meet all the strict ratings for commercial applications. These RJ45 mod plugs are UL94 V0 (IEC 60695-11-10) rated for all commercial installations. These RJ45 mod plugs work great with CMP Plenum, CMR, CM; and LSZH up to B2ca rated LAN cables. They also meet ANSI/TIA 568.2-D, 1096-A; ISO/IEC 11801, 60603-7, 8877:1992; FCC industry standards. PoE/PoH rated for higher current applications.
BrandSimply45
ModelS45-1755P
Part Number150-1016
UPC817777017731
Unit of MeasurePackages
Weight0.5
Cable TypeCategory 6A
MONSTER DEAL
OF THE WEEK
$129.49 EACH
SAVE $14
Dayton Audio HTA20 20 Watt Integrated Stereo Hybrid Tube Amplifier With USB-DAC and Bluetooth 5.0
