  • Sharp 1208PB038A Speaker 8 Ohm
BUYOUT Sharp 1208PB038A Speaker 8 Ohm
Read 1 Review or
Factory Buyouts
Part #299-4131
Factory Buyouts
Part #299-4131
Model: 1208PB038A
Read 1 Review or
The Sharp 1208PB038A 3" x 5" Speaker uses a paper cone and cloth surround to produce natural full-range response from 130 to 15,000 Hz. Thanks to the powerful shielded motor this driver has excellent efficiency for its size.
  • Shielded magnet assembly is suitable for use near sensitive electronics
  • High efficiency to deliver high output with little input power
  • Flat mounting flange for simple front or rear mount installation
  • Perfect for use in slim designs such as sound bars and portable speakers
BUYOUT $2.88
Quantity:Qty: 1-29 $2.88/ea
Quantity:Qty: 30-59 $2.56/ea
Quantity:Qty: 60+$2.45/ea
3723In Stock
The Sharp 1208PB038A 3" x 5" Speaker has a 5" x 3" mounting flange allowing it to easily fit in slim speaker designs. This driver uses a fully shielded motor for use near devices that are sensitive to stray magnetic fields. With over 86 dB efficiency, this driver can produce an impressive amount of output for its size making it perfect for designs such as speaker bars, TV speakers, and portable Bluetooth enabled projects.
BrandFactory Buyouts
Model1208PB038A
Part Number299-4131
UPC848864072128
Weight0.68
Power Handling (RMS)4 Watts
Power Handling (MAX)8 Watts
Frequency Response130-15,000Hz
Sensitivity85.5dB 2.83V/1m
Voice Coil Diameter0.5"
Resonant Frequency (Fs)136.7Hz
DC Resistance (Re)7.173Ω
Voice Coil Inductance (Le)0.1709mH
Mechanical Q (Qms)6.522
Electromagnetic Q (Qes)2.12
Total Q (Qts)1.6
Compliance Equivalent Volume (Vas)0.067ft³
Diaphragm Mass Inc. Airload (Mms)1.95g
Surface Area of Cone (Sd)44.3cm²
Cone MaterialPaper
Surround MaterialCloth
Voice Coil FormerPaper
Depth1.75"
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
