Selenium manufactures a variety of professional horns to complement their range of drivers. Each horn is crafted of high quality molded fiberglass, diecast aluminum, or ABS and provides different angles of dispersion to allow for maximum and optimal sound coverage to suit the particular application. Selenium horns can be used in the most demanding of touring environments. Wide dispersion diffraction horn used in compact P.A. and monitor enclosures. Polpropylene construction.
Specifications: • Horn type: Exponential • Minimum frequency: 600 Hz • Nominal dispersion: 100° H x 40° V • Throat diameter: 1.0" • Mounting type: 1-3/8"-18 TPI • Dimensions: 10.0" W x 5.0" H x 5.7" D • Cabinet cutout: 3-1/4" H x 8-1/2" W • Selenium #HC23-25.
Product Details | |
Brand | Selenium |
Model | HC23-25 |
Part Number | 264-318 |
UPC | 7896359520148 |
Unit of Measure | Each |
Weight | 0.97 |
Product Specifications | |
Construction | ABS |
Entry / Throat Diameter | 1" |
Mounting Type | 1-3/8"-18 TPI |
