CLEARANCE Sanus SFC18B Foundations 18" Center Channel Speaker Stand
Sanus
Part #240-808
Sanus
Part #240-808
Model: SFC18B
The Foundations Steel Series SFC18 is an 18" stand for center-channel speakers up to 35 lbs.
- Adjustable carpet spikes and rubber feet add stability on any surface
- Center channel stand features adjustable brass isolation studs or neoprene speaker pads
- Tested in an anechoic chamber to fine-tune acoustic properties
- Heavy-gauge steel construction provides extreme rigidity and stability
- Resonance damping rings isolate vibrations to provide proper acoustics
