  • Sanus BF31B Foundations 31" Speaker Stand Pair
CLEARANCE Sanus BF31B Foundations 31" Speaker Stand Pair
Sanus
Part #240-767
Sanus
Part #240-767
Model: BF31-B1
The Foundations Basic Series BF31b is a 31" black speaker stand for small bookshelf speakers up to 20 lbs.
  • Energy-absorbing MDF construction increases sound quality by providing acoustic isolation
  • Neoprene speaker pads create a non-slip surface and increase sound quality with acoustic isolation
  • Concealed wire path easily hides and organizes cables
  • Sturdy ABS plastic push-in spikes provide a solid foundation on most any surface
  • Assembly hardware included
CLEARANCE $82.99
3In Stock
The Foundations Basic Series BF31b is a 31" black speaker stand for small bookshelf speakers up to 20 lbs. A solid, energy-absorbing MDF pillar supports a 5" by 5" top plate with neoprene speaker isolation pads for superior acoustic quality. ABS push-in carpet spikes add stability, and a built-in concealed wire path hides speaker cables for a clean and organized appearance in any room.
Specifications: • Dimensions: 12.50" W x 31" H (31.75 x 78.74 cm) • Maximum speaker weight: 20 lbs. (9.09 kg).
BrandSanus
ModelBF31-B1
Part Number240-767
UPC793795260079
Unit of MeasurePairs
Weight15.12
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
