  • SPST 12mm Stainless Steel Waterproof Push Button Latching Switch w/Raised Button and Blue LED Ring
Part #060-651
Part #060-651
Use this heavy-duty, Stainless steel, anti-vandal push-button latching (push on/push off) switch for outdoor and other extreme condition applications. It has a built-in blue light ring for 3 VDC applications.
  • Popular for use in kiosk applications, ticket dispensers, automotive, and industrial-type applications
  • Stainless steel body and IP67 rating for extreme conditions
  • Built-in 3 VDC blue ring illumination for low lit areas and connection identification
  • RoHS certified
  • Includes rubber washer for IP67 rating
  • Easily mounts in 1/2" hole with included shaft nut
  • Tamper proof to prevent vandalizm
Your Price: $5.49
MSRP: $8.99
Save $3.50 (39%)
Quantity:Qty: 1-9 $5.49/ea
Quantity:Qty: 10+$4.94/ea
Order in the next 3 hr 8 min to ship today. Details
1229In Stock
Long lasting professional finish
This anti-vandal pushbutton switch is popular for use in kiosk applications, ticket dispensers, automotive, and industrial-type applications. The stainless steel body and push on/push off button stay looking great even with heavy-duty use. The switch has an IP67 waterproof rating for extreme conditions indoors or outdoors when used with included rubber washers. This switch has a built-in 3 VDC blue light for locating in low lit areas and connection identification. Check the wiring diagram below for where to add a protective resister for higher DC voltage input. The LED only accepts 2 to 3 VDC.
Specifications: • Light rating: 3 VDC • Switch rating: 36V 2A • Terminal rating: 6A 125 VAC • Switch total size without terminals: 1.13" L x 0.55" Dia. • Metal shaft size without button: 0.47" Dia. x 0.74" L • Button size: 0.3" Dia. x 0.06 H • Terminal size: 0.08" W x 0.16" L x 0.025" D
Part Number060-651
UPC848864068701
CircuitSPST
Contact Rating @ Voltage6A 125 VAC
IlluminationIlluminated
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
