  • SMSL SA-36A Pro TPA3118D2DAP Stereo Amplifier 2 x 20W
CLEARANCE SMSL SA-36A Pro TPA3118D2DAP Stereo Amplifier 2 x 20W
SMSL
Part #230-212
SMSL
Part #230-212
Model: SA-36A Pro
The SMSL SA-36A Pro is the perfect amplifier to power small to medium sized speakers in a near-field listening environment. Centered on the TPA3118D2, this Class-D amplifier is highly efficient while delivering deep bass and an expanded sound stage to the listener.
  • Highly efficient operation with realistic soundstage
  • Small size lets you use this amp almost anywhere
  • Simple operation with handsome, minimalist appearance
  • Gold-plated RCA jacks and binding posts ensure maximum signal transfer
Once you have held the SA-36A Pro in your hand, you will know quality craftsmanship and high-end components go into the making of this amp. At its heart lies the TPA3118D2 amp chip. The high efficiency of this component provides smooth detail in the mids and highs and solid, powerful bass. It is fully protected against faults with short-circuit and thermal protection as well as over-voltage, under-voltage, and DC protection.
Use the SMSL SA-36A Pro where space is limited and great quality music is desired. At 3-1/2" x 5" this amp will fit nearly any setting. Operation is quite straight forward with a small power button and large analog volume knob on the front panel. Located on the rear panel are a single set of gold-plated stereo RCA connectors and mini 5-way binding posts. A 15 VDC, 4A power supply is included and provides ample current so this amplifier functions at peak performance.
Specifications: • Power output: 2 x 20 watts @ 4 ohms, 2 x 12 watts @ 8 ohms • Frequency response: 20-22,000 Hz • THD+N: <0.1% • SNR: 102 dB • Inputs: Stereo RCA • Included power supply: 15 VDC, 4A • Power supply input power: 100-240 VAC 50/60 Hz • Dimensions (not including knobs and binding posts): 3-5/8" W x 1-5/8" H x 4-7/8"D.
BrandSMSL
ModelSA-36A Pro
Part Number230-212
UPC848864030951
Weight1.65
Weight Range< 10 lbs.
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
