Virtually any limited space application where up to eight microphones need to be mixed together is satisfied by the RM82. Each of the eight channels has an XLR microphone input as well as a 1/4" unbalanced input. The 1/4" jacks may be internally reconfigured to become channel inserts or direct outputs. Inserts provide a way to get each individual channel signal in and out of the RM82, mainly for outboard processing purposes. A direct output simply takes the signal from the channel only. Each channel has individually switchable +48 VDC phantom power. The RCA prefade output may be connected to the RCA auxiliary buss input for cascading two RM82 units together. This output may also be used for recording purposes, with the aux buss input. The main output for the RM82 is a balanced male XLR. This output may be internally jumpered for a line or mic level. AC power adapter included. Made in the USA.
For more than two decades, those in the know have turned to Rolls for the highest quality, reliability, and value. Rolls is an innovative company specializing in domestically manufactured signal interface accessories, mixers, amplifiers, and processors for the audio professional.
Specifications: • Input impedance: 10k ohms balanced; 20k ohms unbalanced; 10k ohms buss • Signal-to-noise ratio: 106 dB • THD: <0.009% • Dimensions: 19" x 1.75" x 6" (48.3 x 4.5 x 15 cm) • Weight: 7 lbs. (3 kg).
