  • RCF LF18G400 18" Woofer Speaker
CLEARANCE RCF LF18G400 18" Woofer Speaker
RCF USA
Part #294-890
RCF USA
Part #294-890
Model: LF18G400
RCF's LF18G400 is an 18" woofer with linear frequency response characteristics and very high power handling.
  • Remarkable linearity and power handling
  • 4" diameter inside/outside copper voice coil on fiberglass former
  • 2,000 watt continuous program power handling
  • 9 mm linear excursion, 50 mm peak to peak
  • Unique T-pole, curved on top, and 14 mm top plate for minimum power compression
  • Triple-roll surround and fiber-loaded corrugated straight cone geometry
  • Dual spider design with silicon-based damping control
RCF's LF18G400 is an 18" woofer with linear frequency response characteristics and very high power handling. It uses a fiber-loaded cone assembly along with a high excursion triple roll, constant geometry surround. This combination provides remarkable strength and 2" peak to peak maximum excursion before damage. A uniquely shaped T-pole in the motor circuit and 14 mm thick top plate contribute to the driver's superior power handling and low compression. The LF18G400 is ideal for use in applications where incredible power handling, long excursion, and perfect control are required. The robust mechanical design and optimized weight of the device make it desirable for use in fixed installations or portable professional loudspeaker systems.
BrandRCF USA
ModelLF18G400
Part Number294-890
UPC844632090257
Weight33.7
Nominal Diameter18"
Frequency Response25 to 1,000Hz
Sensitivity97.5dB 2.83V/1m
Voice Coil Diameter4"
Resonant Frequency (Fs)28Hz
DC Resistance (Re)5.1Ω
Voice Coil Inductance (Le)2.5mH
Mechanical Q (Qms)4.6
Electromagnetic Q (Qes)0.29
Total Q (Qts)0.27
Compliance Equivalent Volume (Vas)12.71ft³
BL Product (BL)24.2T·m
Maximum Linear Excursion (Xmax)9mm
Surface Area of Cone (Sd)1220cm²
Cone MaterialPaper / Carbon Fiber
Surround MaterialCloth
Voice Coil FormerFiberglass
Overall Outside Diameter18.3"
Baffle Cutout Diameter16.7"
Depth8.3"
Sealed Volume1.31ft³
Sealed F389Hz
Vented Volume2.97ft³
Vented F357Hz
