  • Pyle PP555 Ultra-Low Noise Compact Turntable Phono Preamp with 9V Battery Compartment
4 Questions, 9 Answers or
Pyle Audio
Part #248-4762
Pyle Audio
Part #248-4762
Model: PP555
The Pyle PP555 electronic preamplifier converts phono signals to line level signals. The preamp is perfect for converting phono signals such as turntables to a more suitable line level output. Providing voltage gain to the desired piece of equipment, the PP555 is an essential tool for any studio or home listening room. The unit runs on either a 9V battery or the included 12VDC power adapter.
  • Converts phono signal to line level
  • Ultra-low noise audio operations for improved sound performance
  • Connects to turntables output to amplify phono signal to line level
  • Runs on 9V battery or 12VDC power adapter (included)
Your Price: $19.49
MSRP: $19.99
Save $0.50 (3%)
Quantity:Qty: 1-3 $19.49/ea
Quantity:Qty: 4+$18.03/ea
Estimated back in stock 2/7/2025
Alert Me When Available
The Pyle PP555 electronic preamplifier allows you to convert phono level devices to line level outputs. The unit will take your audio signal and amplify its strength for further processing by your receiver or amplifier. Ultra-low noise audio conditioning circuitry boosts the audio levels to levels that are more manageable for various types of equipment with low distortion. The PP555 is easily installed and concealed in a compact footprint making it a great addition to any musician or producer's studio arsenal. The unit runs on a 9V battery or the included 12VDC battery.
Specifications: • Connectors: RCA in/out with 1/4" output jack • S/N ratio: 70 dB • THD: 0.08% @ 1 kHz and 3mV • Output: 2V max (P-P) at 10K ohms • Frequency response: 20 - 20,000 Hz • Input sensitivity: 3mV at 50K ohms (phono) • Load impedance: 10K ohms • Power: 9V battery or 12VDC power adapter (included) • Dimensions: 3.54" W x 2.13" H x 1.02" D.
BrandPyle Audio
ModelPP555
Part Number248-4762
UPC068888738309
Weight0.85
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
