  • Pyle PFA330BT Mini Audio Amplifier with Bluetooth 90W
Pyle Audio
Part #310-2658
Pyle Audio
Part #310-2658
Model: PFA330BT
The Pyle PFA330BT is a class-T digital amplifier with 90 watts on tap. With its Bluetooth connectivity, low distortion, and acoustically accurate reproduction of music, the PFA330BT is the ideal amplifier for your home audio system.
  • Tone control for personalized listening experience
  • Mic input allows for an exciting karaoke experience
  • Class T amplifier section allows for improved sound quality and efficiency
  • Bluetooth input for wireless streaming
Your Price: $46.49
MSRP: $46.99
Save $0.50 (1%)
Order in the next 2 hr 54 min to ship today. Details
The Pyle PFA330BT is a class-T digital amplifier with 90 watts on tap. With its Bluetooth connectivity, low distortion, and acoustically accurate reproduction of music, the PFA330BT is the ideal amplifier for your home audio system. Adjust the bass and treble to your liking, or bypass the built-in EQ. The PFA330BT features a 3.5mm stereo jack input, 1/4" mic input, and a stereo RCA input.
Specifications: • Max output: 45 watts x 2 @ 4 ohm • Input voltage: 9 - 14 VDC • Power supply input: 90 - 240 VAC • Minimum impedance: 2 ohm • Signal to noise ratio: 80 dB • Total harmonic distortion: 0.4% • Frequency response: 20 - 20,000 Hz • Bluetooth version: 2.1 • Bluetooth range: 30 feet • Dimensions: 6.0'' x 4.6'' x 1.6''.
BrandPyle Audio
ModelPFA330BT
Part Number310-2658
UPC068888760454
Weight1.38
Power (RMS/Channel 8 ohms)0 - 25 Watts
Weight Range< 10 lbs.
Special FeaturesBluetooth
MONSTER DEAL
OF THE WEEK
$23.98 EACH
SAVE 20%
Lepai LP-2020BT Bluetooth Hi-Fi Audio Mini Class D Stereo Amplifier FM Media with Power Supply
