  • Portable 30 Watt Powered Bluetooth Speaker Package with 2-1/2" Full-Range Drivers without Batteries
Part #300-7307
Part #300-7307
This bundle includes all of the electronics needed to construct your own high-end portable battery powered Bluetooth speaker. We have bundled compatible amplifier, power supply, and driver components together to save you time shopping and nearly $20 off the regular retail price. Batteries sold separately., requires 3 x 18650 Li-Ion batteries.
  • Includes a Bluetooth amplifier, battery board, batteries, wires, power supply, and drivers
  • Dayton Audio PC68-4 drivers feature smooth response with true full-range reproduction
  • The Dayton Audio KAB-215 amplifier provides 2 x 15 watts and includes Bluetooth
  • Batteries not included, requires 3 x 18650 Li-Ion batteries.
Your Price: $89.98
MSRP: $116.99
Save $27.01 (23%)
Parts express has put together all of the electronic components needed to build your own 2 x 15 watt battery powered Bluetooth speaker with stereo 2-1/2" full range drivers. This kit is perfect for building a custom self-contained Bluetooth enabled speaker from the ground up or simply incorporating audio capability into any existing enclosure. Thanks to the convenience, ease of assembly, and great sound this kit is sure to impress!
 Recommended enclosure volume for this package is 0.21 ft³ tuned to 70 Hz using 2 ports that are 1" diameter x 3.25" long.
Note: Batteries not included. This requires 3 x 18650 Li-Ion batteries for proper operation. Part # 300-7300 includes batteries.
Included in this package:
Dayton Audio KAB-215v2 2 x 15W Amplifier Board with Bluetooth 5.0
The Dayton Audio KAB-215v2 2 x 15 watt Bluetooth amplifier board delivers high quality sound without drawing a lot power. Its ultra-low distortion and pop-free performance make this hi-fi amplifier board an integral asset in any quality audio build.
2 x Dayton Audio PC68-4 2-1/2" Full-Range Poly Cone Drivers
The Dayton Audio PC68-4 2-1/2" full-range driver features a poly damped woven glass fiber cone, rubber surround, and high energy motor. The Dayton Audio PC68-4 driver will deliver high fidelity and low distortion from compact applications.
Dayton Audio KAB-BE 18650 Battery Extension Board
Lithium battery power is your best option when building high power portable sound projects. Connect and charge three 18650 lithium batteries to your KAB board using the Dayton Audio KAB-BE. Enjoy prolonged listening with this advanced power option.
Dayton Audio KAB-AB L-type Aluminum Bracket
The KAB-AB aluminum bracket makes it easy to securely mount the KAB boards and improve space efficiency . This aluminum bracket supports vertical and horizontal mounting configurations to satisfy different installation requirements.
Note: Crossover components may be substituted with parts of equal or higher quality depending on available inventory.
Part Number300-7307
UPC848864065175
Weight3.44
Cabinet OptionsWithout Cabinet
ConfigurationFull-range
Input RatingPowered
Speaker TypePortable Bluetooth
Woofer Diameter2.5"
