CLEARANCE Platinum Tools 100010C EZ-RJ45 Cat 6 Connector 50 Pcs.
Platinum Tools
Part #150-714
Platinum Tools
Part #150-714
Model: 100010C
Stop wasting time and money using standard connectors. The patented EZ-RJ connectors simplify twisted pair terminations by allowing the wires to be inserted through the connector and out the front. The installer can now easily verify the proper wiring order without having to re-strip wires.
- Thru holes allow wire pairs to be inserted thru the front of the connector
- Works with solid or stranded wire
- Use in category 3, 5, 5E, and 6 compliant data networks
- Faster terminations
- FCC compliant, UL rated
We'll send you an email when Platinum Tools 100010C EZ-RJ45 Cat 6 Connector 50 Pcs. is back in stock or available for preorder.
